Hot Wire Anemometers - where to buy them
I want to use them for permanent flow measuring stations on VAV AHUs in lieu of pitot systems.
I have found the hand helds for air balance applications but I need a permanent installation.
Mike
RE: Hot Wire Anemometers - where to buy them
Although I think the mass air flow meter for intake air in fuel injected automobiles is truly a hot wire anemometer, in the industrial market they're called 'thermal dispersion' sensors/meters/transmitters.
Kurz, Sierra Instrument, and FCI are names that I've used; Google will show you others.
Check Kele or Dwyer too.
Good on ya,
Goober Dave
Thanks for all the information.
I have a supplier working on a quote.
Thanks again,
Mike
