Save Failed: while saving.... out of memory
I am using NX5 on windows XP SP2, every once in a while we are running accross files corrupting on save. When trying to save, an error message will pop up saying, "The following parts failed to save causing the overall save operation to fail:
While saving .........prt: ..........,prt-Out of memory"
There is plenty of disk space and trying to save the file under a different name and/or different drive (local and network) yields the same results.
We do a lot of build to print work, and have to import .tiff images onto our drawings. This is extremely problematic as after 2 images it says "The image is too large" so we go to save and reopen, then these types of saving issues happen.
RE: Save Failed: while saving.... out of memory
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
While saving the CPU usage shoots up to 100% PF Usage goes to 1.6 Gb so memory shouldn't be an issue. The file I am saving is only 3Mb so it is not large either
Best Regards
Hudson
www.jamb.com.au
Nil Desperandum illegitimi non carborundum
NX 7.0.1.7 MoldWizard
My admin guy suggests this too.
I'd also be interested to find out more about it.
Are there any web information resources anyone could highlight (or is it in the Help file)?
Jon S
Medical Design Engineer - Glos. UK
NX 6.0.4.3 / TCE V10.0.3.8.6
Have a look at the following link. I always recommend turning it on (some systems don't like it though and will BSOD so make sure you can dual boot to either on or off)
http:
Anthony Galante
Support Manager/IT Admin
PLM Australasia Pty Ltd
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32
Back to the original concern, I downloaded PDF FLY and was able to take the GM provided PDF GD&T files and turn them into .DXFs and .CGMs I used the file import CGM option and now have my drawings completed. Well worth the $395.00 it cost, simply because it works well and the quality is much better than when inserting a .tiff. I had no idea you could convert .PDFs into CAD files.
Is it a professional IT acronym or abbreviation for something unprintable?
Anyhow I think I will consult my IT guys before doing this!
Thanks though ... looks like it will solve my problem!
