Sending out PDFs with signed stamps (?)
At my old firm, we wouldn't send out the cover sheets for reports if they were signed and sealed, due to worries about plagiarism, and concerns that other folks would reproduce our documents without permission and either omit or change things.
Now I'm at my own firm, and I'm wondering what my policy should be on this. Clearly anyone with photoshop and an original could manipulate a color scan of someone's stamp if they wanted to plagiarize or steal it, so I'm not sure I should be so concerned. What do you guys do?
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
RE: Sending out PDFs with signed stamps (?)
Dan - Owner
http://www.Hi-TecDesigns.com
At a former place of employment they used to keep jpgs of everyone's signature so that people could just stamp them in to documents before issue. I was rather surprised to say the least.
What I have been doing is issuing them with security enabled, so that most people can't extract the pages, or sections of content without access to the appropriate security settings. I've also considered going to digital signatures, and including 'print only' watermarks that don't show up when the document is viewed in a browser.
Worth considering is the fact that not all PDF viewers respect the security settings, I believe there are a few Linux viewers that bypass the settings.
Not only that, but plenty of freebie and <$50 programs that will remove PDF security settings with no password/key required.
Dan - Owner
Y'all see any major problems with that?
Around here all documents must either be stamped and signed or marked "preliminary" or "draft" or "not for construction" or similar. Un-sealed final documents are not allowed at all.
Results would obviously be different in places like USA.
A. A permanently legible imprint of the registrant's seal and signature shall appear on the following:
1. Each sheet of drawings or maps;
2. Each of the master sheets when reproduced into a single set of finished drawings or maps;
3. Either the cover, title, index page, or first sheet of each set of project specifications;
4. The cover, index page, or first sheet of addenda or change orders to specifications;
5. The cover, index page, or first sheet of bound details when prepared to supplement project drawings or maps;
6. The cover, index, table of contents page, or first sheet of reports, specifications, and other professional documents prepared by a registrant or the registrant's bona fide employee; and
7. Shop drawings requiring professional services or work as described in the Act. Examples of shop drawings not requiring seals are those showing only:
a. Sizing and dimensioning information for fabrication purposes;
b. Construction techniques or sequences;
c. Components with previous approvals or designed by the registrant of record; or
d. Modifications to existing installations not affecting the original design parameters and which do not require additional computations.
B. A label describing the name of the project and an original imprint of the registrant's seal and signature shall be applied to all video cassettes containing copies of professional documents.
C. If a professional document is stored, filed, or provided to a client, regulatory body or any other person for any reason by computer disk, tape, cd, or any other electronic form, the registrant shall mark each professional document "electronic copy of final document, original sealed document with" and identify the registrant's name and registration number.
D. A registrant shall sign, date and seal a professional document before the document is submitted to a client, contractor, any regulatory or review body, or any other person, unless the document is marked "preliminary" or "not for construction."
E. For purposes of subsection (A) all original documents shall include:
1. An original seal imprint or a computer-generated seal that matches the seal on file at the Board's office;
2. An original signature that does not obscure either the registrant's printed name or registration number; and
3. The date the document was sealed.
F. Methods of transferring a seal other than an original seal imprint or a computer-generated seal are not acceptable.
G. An electronic signature, as an option to a permanently legible signature, in accordance with A.R.S. Title 41 and Title 44, is acceptable for all professional documents. The registrant shall provide adequate security regarding the use of the seal and signature.
Mike Drinkwater, P.E.
http://www.mdrinkwaterengineering.com
Civil Development Group, LLC
Los Angeles Civil Engineering specializing in Hillside Grading
http://www.civildevelopmentgroup.com
http://www.civildevelopmentgroup.com/blog
SFWMD, on the other hand, has moved completely to digital submissions. They want you to send one letter that has your stamp on it, then they file that with a project number and let you submit PDFs for the entire process. Very convenient.
I'm sure there is other software out there along these lines.
K
