Importing parasolid files
I have solid edge V18. I am trying to import an solidworks assembly into S/E. When I try to open it, it says the parasolid body could not be extracted. I guess this because I am using an older version of solid edge which is not compatible with latest Solid Works format.
Is there a way around this. It would save a lot of time building sub assemblies. Many Thanks
RE: Importing parasolid files
Or, try using step, iges...
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
I'm surprised that SE cannot import SW format files, because SW can import SE format files.
For the parasolid translation just open a SE model and Save As then Options to see the versions that SE18 can use.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
SEv18 was around in about 2007, so if the Solid Works file is a version later than that you will not be able to import it directly.
bc.
Quadro FX4600.
