Epoxy'd Bars in Tension
For a case where there are tension bars doweled into a slab or wall, does the break-out cone for the concrete still exist as a failure mechanism, or is this failure mode for headed studs and expansion type anchors only?
RE: Epoxy'd Bars in Tension
We are Virginia Tech
Go HOKIES
See ' Fastening Technology Manual, by Hilti from their web site.
Also, can you use RE-500 and not RE-500 SD under your building code?
I have not, where can I find that?
Go HOKIES
http
Go HOKIES
They might not mention the concrete breakout strength in the product catalog. It does mention the concrete breakout strength in the product technical guide for the HIT-RE 500SD adhesive, which is very similar to the HIT-RE 500 adhesive. The calculation of the concrete breakout strength would be similar.
The technical guide is very useful and has lots of information that is simple to understand.
Go HOKIES
Do you know if it is a free copy that can be requested from Hilti?
Go HOKIES
mine is the 2006 version....probably outdated.
