Corrosion protection for Rock Anchors
The design for a basment under 5m head of water called for "ground anchors" to resist the buoyancy forces. The contractor has proposed "tension piles" using 40mm GEWI bar. The codes require "double corrosion" protection for ground anchors but are not so stringent for tension piles or soil nails? Although in this case the proposed single tension pile (no initial prestress proposed) has been galvanised to give nominal corrosion protection. The ground water contains no contaminanates.
1. Any expert views on the corrosion protection aspects? 2. Or when a ground anchor is not a ground anchor but a tension pile or soil nail?
RE: Corrosion protection for Rock Anchors
Rock anchors aren't generally as large as piles and nails and perhaps there has been some sacrificial thickness incorporated into the design of those elements.
