fill fluid selection
I must buy the right fill fluid for two similar DPcells;
these fluids have contact with process fluid:
the first with sulfuric acid aqueous solution pH 2
and the second with soda aqueous solution pH 13.
I think that fluids must have some Characteristics:
density > process solution
immiscible with process solution
no reactivity with process solution
operative temperature 0-40°C
low volatility
What do you propose?
low volatility
RE: fill fluid selection
Or diaphragm seals...
