Wrap geometry problem
how can I wrap sketch geometry onto a loft surface ? I know that I can do it onto a cylindrical, spherical, conical, extrude and revolve. Is it possible to do that ?
Thank you
RE: Wrap geometry problem
Depending on what you're trying to do, you can try Insert->Curve->Projected. Not the same as wrap, which won't work on a lofted surface, but it may get you close.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
