Energy Dissipation in Steep Concrete Flume
Is there a calculation to design energy dissipation blocks in a steep concrete flume running perpendicular to a roadway?
The drainage area is roughly 2.5 acres with a 100yr flow rate of +/-12cfs. The concrete flume is 2' wide for 250LF on a 3:1 hill and the velocity will be approaching 20fps. At the bottom will be a large rip rap plunge pool but I would like to add concrete blocks (maybe 4"x4" or 6"x6") staggered every so often along the length of the flume to beat up the water and dissipate the energy. Anyone done this before?
Thanks in advance!! Dave
RE: Energy Dissipation in Steep Concrete Flume
http://ww
Richard A. Cornelius, P.E.
WWW.amlinereast.com
