Stop SW scrunching my Dims
I just upgraded to 2010 and in the draft view, SW keeps automatically scrunching all my dimensions up close. This is after i've placed them and I'm just trying to move them around to look good, SW keeps pulling them back to where they were, or scrunching them up really close.
Can I turn this "feature" off?
thanks
RE: Stop SW scrunching my Dims
I donot know how to turn it off
but try
"Esc"aping out of dim command before you start adjusting dimensions to the desired locations.
It only does it when Dimension command is "ON".
I found that after the first SAVE the issue seems to go away.  It is a bit irritating though.
I have the same problem, and think I have a temp fix. After it scrunches, hit the undo icon. Everything seems to go back and your edits still stays in place. I have call my VAR and SW is aware of this issue.
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2010 SP 3.1
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
