op amp resistance
op amp resistance
so this should be a simple question.
the gain of a op amp in inverting configuation is -rf/ri.
There are many different values of rf and ri can be used set the same gain. How does one practically pick the values.
Im assuming the ri value has to match input or output impedance of the source of the input voltage?
thanks
thanks
RE: op amp resistance
