Solid Edge productivity summits
Since many of the folks on this forum are not on the Solid Edge mailing lists, here is the web page for some free training they are putting on.
http://am.siemensplmevents.com/?elqPURLPage=3363
RE: Solid Edge productivity summits
Ken G.
http://grundey.blogspot.com
Mark
Mark
Mark
How about getting one of your modelling experts to post a solution to the sphere problem.
Maybe a link to a video or something.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
http://yfrog.com/jmq6zhj
Unfortunately, we are all running ST3 right now as we get ready to release so I can't post a video or file. However, the process was this:
1.) Create the first 2x2 square tangent to the surface (easiest to pick a reference play in one of the common planes.
2.) Pattern the square to give you one column of bricks going top to bottom. along the edge.
3.) For each row, pattern the bricks. So, for the bottom 3, you might use the same pattern. For the 4th and 5th brick up, the same pattern, and so on until you get to the top.
Mark
bc.
Quadro FX4600.
