cast resin transformer in outdoor enclosure (UK)
I need to spec and buy a transformer to supply a new plant that we are putting in a remote corner of an existing site. All existing transformers on site are dry types, and site engineers prefer to keep this new one similar. I have looked at GRP enclosures (plus suitable IP rated enclosure around tx)as used by the UK utilities for unit substations, but these seem to use oil transformers inside (but curiously I can't see any oil bund on their foundation drawings). I guess utilities use oil transformers due to cost? None of the suppliers I've approached so far have been able to offer tx and enclosure. So, can a cast resin tx go in this type of enclosure? I've put them many times into rooms with louvred external walls, and this doesn't seem much different. Tx is 1600kVA, 11/0.433V. TIA, Brian
RE: cast resin transformer in outdoor enclosure (UK)
The cast resin transformers can be placed indoors or outdoors.  They will cost significantly more than an oil-filled unit.
David Castor
www.cvoes.com
baj-
Where are you located?
Check out http://www.ritz-international.com for cast-coil transformers. They can be provided in outdoor enclosures.
Have you spoken to Schneider at Leeds, Areva at Stafford, and maybe ABB at Sunderland?
Thanks for replies. Although cost is always a factor, I need to try and fit in with current equipment on site. I have tried Schneider and ABB, both of whom offered only a standard indoor type enclosure. Looks like I will have to get a GRP enclosure myself. Any comments on using cast resin tx in these gratefully received. Thanks again, Brian
baj-
I work for Ritz in the US and I'm 99% sure we can provide cast-coil xfmr in outdoor enclosures.
Putting cast-coil xfmr outside should not be a problem at all.  Maybe you need to talk to someone else at ABB.
David Castor
www.cvoes.com
I'm surprised about Schneider's response.
More candidates:
Baldwin & Francis, Sheffield
Igranic Control Systems, Bedford
A rare piece of advice: phone schneider at Leeds and ask them to get a salesman to contact you.  They make packaged substations for indoor / outdoor locations.
There are others who could offer this, as Scotty said.  Also try Brush at Loughborough
As an aside, we are moving over to Midel (KNAN), midel is a flame resistant, biodegradable liquid.
We have nothing against cast resin units, only that you have no pre warning of failure.
