UG-27 or Appendix 1
UG-27 or Appendix 1
How does Compress determine whether to use UG-27 or Appendix 1 equations for calculating required thicknesses for, say, nozzle reinforcement calculations and unstayed flat head coefficients? I've seen both used in the nozzle reinforcement area calculations in 2 different models of the same vessel.
Fitter, happier, more productive
RE: UG-27 or Appendix 1
"Although this forum is monitored by Codeware it is not intended as a venue for technical support and should not be used as the primary means of technical support."
Tom Barsh
Codeware Technical Support
www.codeware.com
