Best Way to draw a wire connecting two assembled components
Hey, This is my first time on the forum and I'm hoping someone here can help me out. I'm using SW '05. I was wondering if anyone knew the best way to connect two assembled components.
The issues I have run into are:
Assembly files don't let you draw circles
Assembly files don't let you sweep, only cuts
What I have done:
Creates start/endpoints for all of the wires (flat, circular faces)
Created a reference plane connecting the two components, spline a "wire", copy the spline into a new part file, sweep, import into assembly. However, it doesn't ever line up perfectly from start to endpoints.
Is there a way to construct a wire within the assembly?
What I have done:
RE: Best Way to draw a wire connecting two assembled components
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
This works even if the parts you attach to move around.
Hardie "Crashj" Johnson
SW 2010 SP 2.1
HP Pavillion Elite HPE
As CBL said you'll need to bring in a part and perhaps edit it in the context of the assembly.
- - -Updraft
Each wire is a separate part that is edited within the assy.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
