some italy drawings labeling help.
5
labelings on bolts&srew:
ins.maschio M3*6
ins.m.M3*6
pen M*10
ins.femmina.M4
ins.femm.M4
ins.f.M4
what's the difference?
RE: some italy drawings labeling help.
maschio = male = external
femmina = female = internal
pen = ?
femm = abbreviation of femmina
f = abbreviation of femmina
m = abbreviation of maschio
I'd expect anyway.
As for pen, well, maybe it's taking the idea of 'male' a bit far in the literal sense and needs an 'is' on the end to make sens.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
pen might refer to pentagonale, which is used to describe nuts with a plastic insert.
Penetration?   Of course, that opens the male-female problem already brought up ... 8<)
ins. should be for inserto (insert) and may refer, afaik, to the hexagonal inserts for screwdrivers (but normally with inches dimensions, unless this refers to a tapping tool) or to the threaded inserts used as rivets, but in this case I can't see how it could be with an external (maschio=male) thread.
pen. is likely for penetration, and could be a variant of an insert.
You should better describe your product or supply a reproduction of the label to get more help.
prex
http://www.xcalcs.com : Online engineering calculations
http://www.megamag.it : Magnetic brakes and launchers for fun rides
http://www.levitans.com : Air bearing pads
