turbo expander
turbo expander
turbo expander
why at start up and low flows we by pass the turbo expander and use the JT valve?
RE: turbo expander
Because the pressure in the plant doesn´t have reach the operation pressure, and is necessary more pressure for lubrication system in turboexpander.
Another reason is avoid the possibility of hydrates formation and reach the RPM of operation in turboexpander and the stabilization in demethanizer column.
RE: turbo expander
You want the plant chilled down and fairly stable before putting the expander on. The expander needs to have clean dry and hydrocarbon free seal gas available at start up also.
