Is there a Voltage regulator with high/low (on/off) pin?
I'm whipping up a circuit that uses +15V via a standard Voltage regulator. I'd like to have the regulator shut off, or turn off, when a transient voltage is applied.
i.e. a separate DC voltage is introduced into my circuit and i want to use that to shut off the regulator.
Can a diode do this?
Thx,
Thx,
RE: Is there a Voltage regulator with high/low (on/off) pin?
As an EE, you should already know the answer to this question.
TTFN
Thanks for your help
TTFN
Benta.
cheers!
