Add comma to drawing dimension - 10,000 instead of 10000
I'm hoping someone can help me toggle between the American and Canadian numbering standards. I want the dimensions in a drawing to have a comma to divide up the number, ie. 10,000 mm instead of 10000mm. I can't seem to find this under Options > Dimensions, where I thought it would be. Thanks.
RE: Add comma to drawing dimension - 10,000 instead of 10000
http://hel
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
Thanks for your response.
The "system separator for dimensions" only seems to apply to the decimal separator. If I uncheck the box I can change the decimal from a '.' to a ','. However I was hoping to put the ',' to separate 10 from the 000 in ten thousand. I've also checked my regional setting on my computer and it says numbers should be separated by commas. Do you know if there is a regional setting in SolidWorks, that seems to be the only other place that could cause a problem.
Caleb
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
The OP is not talking about the thousands separator, not the decimal point separator.
Ten Billion vs 10000000 vs 10,000,000,000
Ten Thousand vs 10000 vs 10,000
Ten vs 10 vs 10.000 vs 10,000 (the latter 2 being shown to 3 decimal places)
The commas make the larger numbers much easier to read. Confusioon can arise when dealing with the smaller numbers.
eg. 10,000 (ten thousand) could be mistaken for 10.000 (ten to 3 decimal places) in some regions.
It can be changed to "." "," or no separator.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
10 000 000.500 000
Easier to read and no creating confusion.
-- Me chE ng2 005
Sorry Chris, that's not the entire story. Continental Europe tends to use commas for decimal places, regardless of units/application. The US & UK use 'dots/periods'.
This is why in 'scientific' circles I'm pretty sure the idea of having a comma or any other indicator every 3 places is out of favor.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
-Kirby
Kirby Wilkerson
To answer the OP's question, it is possible to remove the <DIM> variable from the dimension name and insert the text 10,000. This is of course very bad practice because the number will not necessarily reflect the actual model dimension.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
"Node news is good news."
ht
http://physics.nist.gov/cuu/Units/checklist.html
Working with military contracts (US and Europe) in the past, we have been always mandated to use commas in metric, periods in SI units.
Working within current US and Canada companies, I have seen both.
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
