Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The forum looks great! You guys have done a fantastic job on arranging things there...Your site is very precise and fun to visit..."
Geography
wiazco (Geotechnical)
12 Jul 10 15:46
If I know the natural water content, max dry density, and the optimum water content of a soil, how do you calculate how much water needs to added to acheive optimum water content for a volume of soil? Thanks very much.
Helpful Member!  Ron (Structural)
12 Jul 10 21:23
OK...you're obviously not a geotechnical engineer or you would know this, so I'll assume your handle is an attempt to categorize your problem, not a statement of your expertise.
If you know the moisture content and you know the optimum moisture content, the difference between the two is the amount of moisture you need.  Assuming that you'll compact to the max dry density, then the difference multiplied by the max dry density is the weight of water you will need.  Divide that value by 8.34 lbs/gal(if your density is in lbs/ft^3) or 1kg/l (if your density is in kg/m^3) (someone probably needs to check my conversion!)
Helpful Member!  fattdad (Geotechnical)
14 Jul 10 8:54
As presented in your other post:
If you have one 2,000 pounds of soil with a moisture content of 12 percent and you want it to be 18 percent you do the following:  2,000 x (0.18-0.12) = 100 pounds
That's how much water to add.
f-d
¡papá gordo ain't no madre flaca!
Dozerman56 (Civil/Environmental)
16 Jul 10 19:44
If you're trying to make compaction, bear in mind that while this calc will give you a rough idea, you're probably losing moisture to evaporation at the same time.
Close Box
Join Eng-Tips® Today!
Join Us             Close
