latest nvidia Quadro drivers
Just a notice, tip, or a warning for those who use an older Quadro like mine (FX3400).
I use Windows7 x64 and Quadro FX3400 on SonicView VA2413wm. The current working nVidia driver is version 197.90 Works perfectly. Downloaded the latest (next) version 258.49 WHQL and that one crashed the monitor drivers completely, so that Windows didn't even knew that I have a monitor. I tried to re-install the monitor drivers, but nothing helped except for restoring the system to the previous state. So, be careful if you have a similar set-up. There's a good chance you might run into serious problems. It would probably work fine with newer GPUs.
RE: latest nvidia Quadro drivers
Having said that, did you try installing newer monitor drivers?
One of the good things with Win7 is it's capability to work with a completely new set of hardware without collapsing, the downside is that the default (MS signed) drivers for Quadro are actually completely useless and it was a struggle to force these onto the system. Went through loss of monitor drivers in the process of installing nVidia drivers over MS drivers as well, but only from safe mode, because MS drivers wouldn't budge. The latest, 258 version lead to complete collapsing...
