Radiator shroud material
Where can I found out what type of plastic was used for automotive radiator shrouds from the mid 60's on. It is a flexible dull black plastic. It seems to have some type of fibers in it. It tuurns brittle when old. I believe it is injection molded. Any clues?
Russell Giuliano
RE: Radiator shroud material
If you cut of a slim slither and burn it and blow it out then smell the smoke, if it's PP it smels like wax or oil.
If it's nylon it smells like celery or feathers.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
If you cut of a slim slither and burn it and blow it out then smell the smoke, if it's PP it smells like wax or oil.
Pat
for site rules
I was thinking mid 80s when I posted above. Cars here did not have fan shrouds as I remember in the 60s, they only became common in the 70s.
Pat
for site rules
Thanks for your help.
Russell Giuliano
