Creating a sphere
Creating a sphere
Creating a sphere
Hallo all,
I'm a novice at ABAQUS 6.9 and have a little problem. I'm trying to create a sphere-model and it doesn't work.
I hope the problem not too easy for you...
It would be fine to get a response.
Thank You
RE: Creating a sphere
What's the problem? I mean: when did u encounter problems?
About modeling the part or what else?
It's about modelling. I've creating a circle in the "sketch". The problem is to to get a sphere out of the circle when I want to creat the part
Than You
Create part> type: Revolution>
Create half a circle, connect the 2 free ends with a line.  Should look like a "D".  Accept the sketch revolve 360deg.  I hope this helps.
Rob Stupplebeen
It works!
Thank you so much...
This was very helpfull for me.
