Saving e-drawings to .pdf
I don't see a way that e-drawings can do this. Is there a program available that can take an e-drawing and save it as a .pdf file?
RE: Saving e-drawings to .pdf
Google "pdf printer freeware" & you will get a lot of options.
This will be a virtual pinter which can be used to create PDFs from all the programs which can print.
  CutePDF
Not immediately clear on the web page but CutePDF writer is free. Should have mentioned it earlier! I have used it for years.
BullZip also works great, lot of options to set/choose.
"If you have SolidWorks, why not make the pdf from there?"
This option is available from SW2007 onwards...
Cute PDF Writer and Ghost Converter did the job. Thanks!
