Steam turbines rotor overspeed test
Does anyone can tell me if there's any standard or code defining minimum overspeed values to factory test new steam turbine rotors for a power plant (170 MW, 2044psi, 1000F, 3600 rpm):
105, 110 or 120% of nominal speed?
For how long must be maintained this speed?
Thanks in advance for yout help.
Javier Guevara E.
Projects, Mechanical Engineer
RE: Steam turbines rotor overspeed test
If I had to spec, the design of the controls should have an emergancy peak speed value. that is peak speed following a full load rejection WITH a 100% failure of the governor valves, so that valve closure is intiated at emergancy trip speed. thus the peak speed is nomally just over 120% rated.
a hold for 3 minutes is what I seem to recall
Machanical, a bolt on a spring,the faster you turn the further out the bolt goes , at the setpont tit hits a finger and dumps the hydraulic system closing the stop valve.
An electronic OS system looks at a speed pickup or a tachometer and then trips a solenoid that dumps the hydraulic system.
The OEM should have supplied settings and a procedure for the overspeed test.
I reviewed our specifications for turbines and found no requirement for a spin test above running speed. For large turbines, we would perform the balance at full running speed. We would have a full test of the overspeed trip protection system at the OEM shop and again once the turbine is installed.
Johnny Pellin
I recommend holding at 120% speed long enough to obtain stable vibration readings. These readings should not exceeed the allowable vibration at rated speed by more than 100%.
For generator rotors, the winding needs to be checked for shorted turns with a flux probe during overspeed testing. For turbine rotors, a visual inspection is necessary after overspeed to ensure no blading or shroud distress occurred during the test.
Best of luck!
