Failure in Wind Generator
Dear All
Attached you will find one picture of failure, in one 2 Speed Low Voltage Squirrel Cage Induction Wind Generator: 1300/250 KW 690/690 V 1219/248 Amps 1510(4 Y)/1008(2 D) Rpm 50 Hz.
The Failure happened in the Low Speed winding,
What happened ?
Could be currents induced in the unergized winding circulating by transformer action? The problem could occur when the machine was working in low speed and one of the parallel path was opened in one phase?
Thanks for the Inputs
Carlos
What happened ?
Carlos
RE: Failure in Wind Generator
Muthu
www.edison.co.in
Zlatkodo
