Pro Engineer (ProE) Wildfire 3 and Vista - annot connect to flexlm
I am trying to run the setup for Pro Engineer (ProE) Wildfire 3.0 on my Vista 32 Bit OS
I am running Vista Home Premium – Service Pack 1
I was able to run it fine on my old XP machine. But had to trash the old PC when the motherboard failed.
When I doubleclick the ptcsetup.bat file and specify the name of the flexlm license server and the port # it immediately comes back with the following:
"Warning: No FLEXnet licenses were detected at the specified location. Please verify that a FLEXnet server process is running on the specified host(s). Also verify that server port numbers were specified correctly. Select OK to continue or Cancel to change your input."
I can ping the remote server OK. I can telnet to the remote server on the port specified OK.
I have tried the "Run as administrator" option when executing the .bat file. i have even tried compatabiliy mode and run it as a XP program in Vista. But still get the same error.
I think its an issue with Vista blocking something but cannot check and see what it is. Is there a log file that I can look at that will give me some info? Nothing in the Event Viewer as well.
My frind just re-installed the same app on his XP machine and connected to the same flexlm license server on the same port and was bale to download a license successfully.
Any help will be greatly appreciated.
RE: Pro Engineer (ProE) Wildfire 3 and Vista - annot connect to flexlm
Hi
I think on Vista Home Premium – Service Pack 1
will not run
You must have Vista Professional
regards
Wildfire is very nice, if you know,
how work with him
Is this documented somewhere?
See this page for system requirements for Wildfire3.
http://www.ptc.com/WCMS/files/71138/en/proewf3.pdf
Windows Vista Business Edition
Windows Vista Ultimate Edition
Windows Vista Enterprise Edition
Ben Loosli
