Maximum patch size for tank shell replacement
Is there a maximum patch size for tank shell replacement? If yes, how to determine the maximum size? I don't see it is required in API 653, but our client asked about the maximum size of the patches.
RE: Maximum patch size for tank shell replacement
If to replace part of the ring, do I need to consider that when cut out the old shell, the roof will collapse?
If you consider this to be a possibility then yes you need to check it. Any modifications/rapairs you intend to do need a full assessment to ensure the tank is "stable" during all operations you intend to do to is and under all possible loading scenario's otherwise you are not "engineering" the proposed repair !!!
Tell your "client" that the maximum patch size for a flat bottomed tank whould be one that is the exact size of the tank shell.
