Export step and parasolid from command line
Does anyone know how I can export a part file as a step and a parasolid from the command line. Basically I want to be able to convert all files in a given directory to step, parasolid and jt (I already have a batch file that does jt) automatically by running a bat file, but I have no idea how to get a parasolid and I don't know the proper commands to get the step exporter to work without going through the interface.
Thanks.
Thanks.
RE: Export step and parasolid from command line
To get there in Windows:
START > PROGRAMS > UGNX_ >TRANSLATORS > STEP203(or Whatever) > EXPORT
ugii_base_dir\ugii\ug_inspect -extract_all mypart.prt
I hope this help
Didier
http://www.psi-cad.com
