How can I define a rigid ring in a cylinder (shell)?
Problem:
I have got a cylinder that is clamped at the bottom edge. the top edge is supposed to be able to move in the global coordinate system - but the top nodes shall be rigid body (a stiff rigid ring). It is possible to model this by using *rigid body, but the problem is that a reference point has to be defined (leading to a movement of all nodes bound to this RP) and the model has to work for not symmetric loads on the shell (and buckling as well) as well.
Can anybody help?
thanks,
anton
Can anybody help?
thanks,
anton
RE: How can I define a rigid ring in a cylinder (shell)?
(i) a set of beam elements with very high second moment of areas and elastic stiffnesses or
(ii) a set of link/spar/spring elements, with very high stiffness
both should work equally well, but you will not be burdened with the reference node.
Hope this helps,
- - D R E J - -
