Need hydraulic solenoid valve recommendation
Does anyone have a recommendation for a zero-leakage hydraulic solenoid spool valve for water service?  This 2-way, 2 position normally open valve could see up to 1000-1500psi.  Size is also an issue and I would prefer the valves be small since I have to cram a bunch of them in a small space.  If there's nothing available out there, do you have any recommendations for a custom valve manufacturer who could handle this type of valve?
Thank you.
