wire diagram for a leeson-taylor mtr.
The mtr plate says "connect for wiring diagram supplied with motor". I dont have this. Can anyone help me? model A4S17DR46B OR A4S1-DR46B. Orange wire marked RB, White marked R21, Black w/White stripe no marking, Green w/Yellow stripe marked R14. Its single phase.
tks, paul
RE: wire diagram for a leeson-taylor mtr.
I would Google. You may also.
Bill
"Why not the best?"
Jimmy Carter
I did before I posted here.
Are you sure about Leeson_Taylor?
Green with yellow stripe is often ground. Check for continuity from this lead to the motor frame and NO continuity to the other two leads.
More information would be helpful.
Pictures?
Nameplate data?
Bill
"Why not the best?"
Jimmy Carter
part number.  4*066 27
* after the four is either a space slash OR a 7, as 4 /066 27 OR 47066 27
Not sure about the 27 at the end. I can barely read it. Also, maybe the space before the 27 is really a letter or number, I dont think so, but not sure.
Is there any chance that this was a drive motor for an electric clothes drier? There are several indicators but none definite.
Bill
"Why not the best?"
Jimmy Carter
Dont know, does that matter? I want to power it and see if it works.
Double throw centrifugal switch to turn off heat source if the motor stops. Wires would be L1, L2, ground, and heater switch. Other than that, no.
Indications;
Google doesn't find Leeson-Taylor. May be OEM motor built to OEM specs by Leeson.
Very small drive pulley, Common on driers.
No JB or peckerhead, and OEM connector on the ends of the wires.
Green/yellow is often ground. That leaves three wires. not common for many single phase motors of that physical size.
Did you check for ground continuity yet?
What voltage is shown on the nameplate?
Bill
"Why not the best?"
Jimmy Carter
1725rpm
206-230VAC 60Hz 1PH
1/3HP
gr/yel is gnd.
See if one wire goes to the centrifugal switch with no continuity to anything when the motor is at rest. Then the two remaining wire would be the power leads. Check the condition of the centrifugal switch. The motor may have been removed from service due to a faulty switch.
Bill
"Why not the best?"
Jimmy Carter
or and bl = 5.8 ohms
or and wt = 5.9
bl and wt = 0.4
all other combos infinite resistance.
If you are wanting to try and run the motor, the line's are clearly marked. White and orange. As to what the black lead does, It doesn't look like it is coming directly off the switch( normally open then closes when motor is running to maybe start some type of heat source, as suggested above), but it looks like it is coming off of one side of the start winding on the terminal board of the motor.
The other diagram that was shown in your last post does not correspond with the orange, white, and black leads. They only correspond with other connections that are on the terminal board of the motor that are on your next to last post. It is basically telling you to interchange positions of lead #5 and lead #8 on the terminal board to change the rotation of the motor.
please explain: "the line's are clearly marked"
On your  14 Jul 10 1:59 post the picture  that was posted shows a terminal board on the motor.
The white lead terminates on the right. The board reads "LINE". One of your LINE's goes here. The orange lead terminates on the left. The board reads "LINE". The other LINE goes here.
Tks
powered it and it spun for 30 seconds and stopped. Removed power and 5 seconds later heard a click. Powered it and it spun for 15 seconds and stopped. Removed power and 30 seconds later I heard a click. Powered it and it spun for 5 seconds and stopped. Removed power and felt the mtr case and it was hot. After about 5 seconds I had to remove my hand. At least a minute went by before I heard the click. Fixable or scrap it?
The click is probably a Klixon thermal protector resetting. The motor is getting hot quickly for some reason - maybe a defective centrifugal switch leaving the starting winding in circuit when at running speed. If your mechanical skills are reasonable then you might want to remove the NDE bellhousing and take a look at the switch and make sure it operates freely. Otherwise scrap it and get one on ebay. smile
take your thumbs and press down on the plastic ring while pulling out on the weights against the springs.  Work it up and down gently.
Something is stuck in the centrifugal mechanism, might need some lubrication.  You should be able to get it loosened up so that as soon as you release the weights, the plastic ring snaps back toward the bearing on the shaft.  Pushing on the ring (away from the bearing)should also make the weights move outward, but it can be a pretty stiff push to get them to move, so start them moving with your fingers while putting pressure with your thumbs.
The weights move in a direction to stretch the springs.
What ccjersey says. This is a common mechanism, ccjersey is not guessing. From his instructions he has probably repaired several identical switches and a lot more very similar switches.
Bill
"Why not the best?"
Jimmy Carter
I tried what ccjersey said several times and will continue to do so. So far that plate wont budge, and its hard to see below the plate, but I might try spraying some lub down there. I will keep working on it and will post my progress.
I got it loose and the mtr now works. Thanks much.
>paul
PS: I have another mtr that I cant figure out, I'll start a new thread.
