"Check Submitted" but never starts/finishes
I'm running ABAQUS/CAE. I created a job and ran "Data Check". It says "Check Submitted" next to the job, but the Monitor shows no progress, and it's just been hanging there like that. I tried to use "Kill" to stop it, but it keeps running. I tried restarting ABAQUS, my computer, etc., but I can't kill it/get it to finish.
Does anyone know how to fix this?
RE: "Check Submitted" but never starts/finishes
Rob Stupplebeen
Rob Stupplebeen
1. Close CAE, go the work folder and delete the <jobname>.lck file. When you restart CAE the job should no longer show "submitted"
2. Sometimes this works. But I have to warn you that I have only done this a couple of times and so far it doesn't kill the CAE and I can then rerun the job without restarting but it's behavior in your case may be different. With CAE still running go into the task manager and kill the "Standard" process. This will abort the check. I haven't done this with an Explicit analysis so I don't know the name of the process to kill.
Neither of these will fix the problem that is causing the check to hang up.
HTH,
Dan
You can check that by looking at the queue using the FLEXnet license manager. If that is the case you can kill the job using Task Manager (Windows) or the kill command (UNIX/Linux). You can also kill the current job(s) taking the resources if they are on your local machine.
Nagi Elabbasi
Veryst Engineering
