Memory allocation for V5R19??
How much memory can be allocated to CATIA?  The current setup is XP 64bit w/ 8G of RAM.  I believe right now 3G is allocated for CATIA and when I get close to that value CATIA crashes.
RE: Memory allocation for V5R19??
Sounds like a 32bit software limitation, why do you use 32bit catia on a 64bit system?? If you use 64bit catia there is of course a theoretical limit but it is not a realistic problem, have had cases where I had 10G allocated to a 64bit Catia on a 64bit system
How can we find out which version of CATIA is installed on the machine (32 bit or 64bit)
Thank you.
look in the install directory is the sub directory of the B19 directory Intel_a or Win64. The software management tool should also tell you.
dtwo,
  virtual memory should be >= Ram.
Derek
