Stage pressure vs extraction pressure
With turbine deposition or fouling all the information Ive studied says that stage pressures increase .So is that saying heater extraction pressures would follow suit and increase?
RE: Stage pressure vs extraction pressure
The heater extraction steam condition is a function of whatever the extraction stage produces.  If the stage pressure is increased for whatever reason, then the extraction pressure will follow suit.
rmw
