SAE B92.2 vs DIN5480 & ISO4156
We currently are design a hub that uses a standard female spline from the B92.2 SAE standard. We have run into the problem in specifying the correct tolerance class (4H, 5H, 6H, 7H). In the B92.2 it does not have calculation for the tolerance class or explain the tolerance classes.
I have seen on the forum many people recommending the DIN5480, would I find the same spline in this standard as in the 92.2?
RE: SAE B92.2 vs DIN5480 & ISO4156
DIN 5480 and B92.2 use different tolerancing systems and also have different dimensioning.
Ron Volmershausen
Brunkerville Engineering
Newcastle Australia
http://www.aussieweb.com.au/email.aspx?id=1194181
