I want to print out a cross section.
I have a drawing of my assembly, and I just want to print out the cross section of it; however, when I delete the view I chose it deletes my cross section as well.
RE: I want to print out a cross section.
Don't print the whole sheet, select the Print Area option.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Where would we be without sat-nav?
Right click on the section view and choose "Draw in view." Then print.
To delete the view and keep the section, right click on the section view and choose "Convert to 2d View." Then you can delete the view it came from without deleting the section.
Terry
It all depends on what you want to do, but another option would be to use a view with a section view from the assembly.
Just a thought
Patrick
