ug nx6 exploded view problem
when i create an exploded view in ug nx6 some parts disappear. they still live in the assembly tree and if i remove the explosion they show up. has anyone had this happen and is there a fix?
thanks.
RE: ug nx6 exploded view problem
They disappear from the modeling view? Perhaps the components have been moved past the view clipping planes; refresh or regenerate the view and see if that helps.
or one solid body went into another solid body.
Another possibility is that the missing parts were hidden using the "Hide Components in View" command.
Did you try to fit the view ?
And also have a look at preference visualisation performance
I hope this help
Didier
www.psi-cad.com
