Recommendation for a Polymer?
I'm looking for a polymer that will satisfy the following requirements :
1) Flexible enough to wind around a spool with a diameter of, say, 1/2 inch.  Film can be a few mils thick.
2)  Reasonable transparency in the 1-5 micron range (short-IR)
3)  Retains flexiblity between -100 degrees C to +100 degrees C
Thanks in advance
RE: Recommendation for a Polymer?
Styroflex, a type of SBS elastomer from BASF
Chris DeArmitt PhD FRSC CChem
www.phantomplastics.com
Consultant to the plastics industry
Hi Demon ,
SBS in no good , becuase the max temp is 80°C not in continuons!! the SEBS is little bit better because it can reach 100°C , there is another polymer flexible , if you not FDA request you can use TPV.
ciao
xpolymers
italy
Have you considered silicone rubber film?
Victrex makes  a PEEK coating that comes in a film which you wrap around a part and then put it through a centering process to cure it.  I think they also make a liquid peek option aswell.   In addition you might try Teflon tape?  A company called FAST Houston makes/offers all of these products or services.
