Power problems in New York
This article discusses the current condition in NYC with triple digit temperatures hovering about for about 5 days. I wonder if one of you utility gents can answer a question that arises from a statement in the article where a substation manager requests "...a 4kV generator...". Is this the typical ignorant reporter misquoting someone? Or is there a method to temporarily boost voltage on the grid using a portable generator of some kind? Sounds like quite a piece of equipment.
I am aware of utilities using RC systems to shut down or cycle power to customers whom sign up for the "brown-out box", where for a favorable rate one volunteers to enable the utility to cut power in times of high peak demands. But this articles states that Carrier, a controls/HVAC manufacturer does this through a programmable thermostat which is centrally controlled, which cycles the AC every 30 minutes. Wasn't aware of that one.
Thought this article was interesting.
Thank you and regards,
EEJaime
EEJaime
RE: Power problems in New York
EEJaime
I can see using a local 4160 V generator at a substation to reduce transformer load or in the event of a transformer failure.
Reporters can be pretty clueless about anything technical. But we have fewer and fewer of them to worry about.
David Castor
www.cvoes.com
Has anyone run into the HVAC load shedding scheme described in the article?
EEJaime
-John
