ASME B31.1 & Section I material identification
Is there a requirement for Pipe spec markings and heat numbers to be transferred before cutting a pipe into pieces to ensure identification and traceability of every piece in the above ASME Codes for Code work? ASME Section I PG-77 only refers to plate identification. If there is please give the applicable section in these Codes.
RE: ASME B31.1 & Section I material identification
