Make coplanar with ST command
I attach a part and an image.
I would like to make coplanar a face to another in sheet metal.
I can't able to accomplish this operation.
Can someone suggest me something ?
Thank you...
Using NX7.0 and TC8.1
RE: Make coplanar with ST command
use replace face its doing the same thing - look that the selection focus is on intire assembly
doesn't work.
Can you try to obtain the needing with the part that I attached before ?
Thank you...
It is done in Nx sheetmetall - I'm still examine.
Question I have , why don't you pull you flange parameters
to 90° ? the other thing is - that flatting doesn' t work;too.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
it's true, we had already covered this part, but I've changed something and now I can't able to obtain as before.
Thank you...
