how to save animation?
hi.
when i execute the save animation buttom in ansys workbench, appear a dialog box that say: the display settings are windows aero and image capture might not work. please change them to another theme.
exactly, i save a animation but this have not my model, it's empty.
the question is, how can i change it?
thanks in advance
thanks in advance
RE: how to save animation?
If you're using XP, Vista or 7, you will have different ways to adjust the display themes so I think you should try to apply the simplest theme (perhaps the one called "classic" if such a theme exists) and see if ANSYS works with that.
Another option might be to move to another computer with a different operating system that doesn't have aftermarket themes applied to the OS.
