NX 7.5: Replace with Independent Sketch - possible to reverse?
NX 7.5
The new function, "Replace with Independent Sketch" enables replacement of a linked curve feature with an independent sketch.  This has clear advantages for a development-release workflow, where WAVE-linked sketches would be replaced with Independent Sketches upon release.
But, is there a way to reverse the action?
Or, is the best way to reverse the action to make a new WAVE link of the sketch and Replace the now-Independent Sketch with the "new", WAVE linked Sketch?
RE: NX 7.5: Replace with Independent Sketch - possible to reverse?
Sounds like you've found a reasonable workflow.  Go for it.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
It's very easy to create a new linked sketch before, then replace the independent sketch by the new linked sketch. (Edit Feature replace)
Didier
http://www.psi-cad.com
