How close by code can two welds be made to each other?
Sorry folks, new to the forum and I believe I posted my question in the wrong area. Looking for feedback on the following thread (posted to the Welding, Bonding & Fastener engineering forum):
thread725-276115: How close by code can two welds be made to each other?
RE: How close by code can two welds be made to each other?
Those questions are again:
• What, if any, is the relevance to ASME B31.1 of Section VIII Part UW Reqs for Pressure Vessels Fabricated by Welding, Series UW-9, Design of welded joints, paragraph (d))?
o If a pipe was constructed to B31.1, does the boiler code VIII apply in any way to this situation?
• What relevance does NDT have to assuring that the proximity of the welds is satisfactory?
o Can NDT provide assurance that a design meets code?
-None outside of recommended practices.
-No
-None
-Not specified for B31.1
-None
-That's the entire purpose of NDE, albeit not in regards to proximity of two welds.
Long story short, B31.1 is not going to specify a minimum distance for two welds unless it refers to the minimum distance between adjacent openings (see interpretation B31.1-22-7). B31.3 won't either, with the exception of addressing overlapping reinforcement.
h
Steve Jones
http://www.oilandgaspeople.com/cv/11499664
http://www.linkedin.com/pub/8/83b/b04
