Suction lift Gear Pump
I have an application to "Top offload" viscous chemical (1600cP) from the Rail car and the pump is located at the Grade.
The elvation of the bottom of the rail car and highest point of the loading arm is 20ft. Is it possible to have gear Pump which unload the material without pressurizing the Rail car with Air/Nitrogen?
RE: Suction lift Gear Pump
The flow may start faster if you pre-charge the siphon pipe with the chemical.
Mike Halloran
Pembroke Pines, FL, USA
Mike Halloran
