CATIA V5 Conditional Statements
I can't seem to figure out the syntax, or if this is even possible. I'm working in the Law Editor.
I would like to write a conditional statement that will change an angle in a part based on a string type parameter.
Ex. IF `valve` = closed, THEN angle = 90deg
Any help/examples/syntax pointers would be appreciated.
Jake
Jake
RE: CATIA V5 Conditional Statements
if 'valve'=="closed"
angle=90deg
Jake
angle=90deg
else
angle=0deg
Anything else I should be doing?
create a simple sketch that you can link Angle to.
create rule
if Valve == "closed"
Angle=0deg
else
Angle=90deg
this will prove the concept
