heat exchanger size and flow
We want to change our actual heat exchanger that has the following specs:
SQ.FT: 250
Tube diameter: 3/4"
# tubes: 250 tubes
Length of tubes: 5 feet
For a bigger exchanger, with the following specs
SQ.FT: 338
Tube diameter: 1"
# tubes: 261 tubes
How is our flow going to be affected?
thanks for your help on this one
RE: heat exchanger size and flow
Q=ṁΔT
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
See attached.
Note that G=mass/(time * area)
Your pressure drop will change by 0.8 power
Thank you both for your replies:
 Chance17: I still cannot open your file...
 vpl: how can i apply the q=mxcxAT formula, are the q are AT equal for both exchangers?
bragamor i think you should hire a professional consultant. This is not a "free consultancy service". What will you do if it does not work as you expect? Tell your boss that "those amateurs (no offence guys) didnt know what they were talking about"?
Or - talk to the vendor...
Best regards
Morten
bragamor . . . insufficient information is given to answer your question (spedifically, process flow conditions for both streams).  MortenA recommendation is good!  changing the physical characteristics of a heat exchanger without obtaining sound technical (heat transfer specialist) information is risky and bound for operational problems.
good luck!
-pmover
