Angle of Internal Friction of Crushed Stone
Hi everyone,
I am looking for friction angle of Crushed stone. The crushed stone was used in two layers as a foundation support for oil tanks. The first layer has a gradation of crushed stone between 20 to 31.5mm. The second layer has a gradation of the crushed stone between 8 to 16mm. The crushed stone were well compacted.
Could anyone advise me which friction angle for the two layer I should use for modeling? Thanks.
RE: Angle of Internal Friction of Crushed Stone
(Tell me you're not doing bearing capacity though as these two little sublayers are trivial compared to the bulb of shear that extends WAY below the thickness of some subbase materials.)
f-d
¡papá gordo ain't no madre flaca!
Don't you think 40 deg is too small? If the crushed stone is well compacted, it can be high, but may be maximum is 50deg. What do you think?
f-d
I am not able to download the paper
by J. Michael Duncan
Notes of a lecture presented at the
Kenneth L. Lee Memorial Seminar
Long Beach, California
April 28, 2004
Can't locate it any longer on the web
I'm going to attach temporarily the document to one of those sharing sites.
The presentation was freely available online, to my knowledge there are no copyrights but if anyone knows otherwise I'll refrain.
http:
thanks for that Duncan paper
