Class B splices
Class B splices
Class B splices
I have a tilt up wall with 12ft high
I used a dowel #8 Rebar for the connection from footing to wall. Using the ACI 12.2.2, the length of Ld must be in 48".
Chapter 12 gives two option on Ld. Class A splices must be 1.0Ld, while Class B must be 1.3Ld
My question is, when are we going to use the Class B splices?
Is it for seismic connection?
Please enlighten me on this one.
Thank you
Poems are made by fools like me, but only God can make a tree. engineers creates wonderful buildings, but only God can creates wonderful minds
RE: Class B splices
What is the purpose of the connection?  If only for shear as is the case for most tilt wall construction, the lap lengths do not apply.
RE: Class B splices
Class A Splices are when less than 50% of the splices are in the same location - which means that the splices would be STAGGERED.  This verbiage is in ACI 318
You likely have Class B since they are dowels and the contractor will want to use the same length for ease of installation.
48" lap splice seems low for #8 - what strength concrete are you using?
also, as hokie asked, are you 'fixing the base' ?
how are these dowels installed if it is tilt-up?
RE: Class B splices
its for the shear of the base connection of wall footing and the tilt up wall.
f'c is 4000psi while fy is 60000psi
